I will post this again for the benifit for those who would like to try an awesome gasket. I now have some experience with them. Ran a 7.02 with a 60 ft of 1.54 with them last night in the 1/8 mile, and everything is still perfect. COMETIC is the company producing the gaskets but buy them through: cvproducts.com for a $40 break on two gaskets VS. buying them from Cometic direct (i know, weard huh!). They are multilayer steel shim embossed and are spring steel instead of carbon steel. Embossing will not take a set. Torque ARP bolts to 85 and run it! No retorque required!! Install is dry due to the coating them put on hem at the factory. Part number is: C5692. Order 2 of that part number. This is my experience with them only and of course all are free to use what you like. Hope this helps someone.
Mitch
