Originally posted by Tim Cucci
The process is not the problem. They can be tig welded or mig welded. You have to use the correct filler material and use an inside purge. 309 stainless is a bi-metal welding material and works great on the headers. I prefer to use tig because you can control your starts and stops and thus control warpage to a minimum when making repairs. Making repairs are considerably different than a factory productin weld. The factory welds seem to be almost just an overlay. Grinding and preping the factory weld and cracks is somthing else to before welding. There is a lot more to making the repairs than just welding over the cracks and factor welds. Tig works well because you can purge the inside of the header and prevent internal defects which occurs when welding SS.
Just my opinion.
Tim
15 Nuclear Plant Welding Certifications. From 1/4" SS tubing to Plastic.
Tim - Why does TIG inherently create an inside purge? Is there enough fouling of the pool on the back side? If so, then you're over penetrating. Most cracks I've ever seen are pretty thin and wouldn't require back gassing. TIG and MIG shouldn't matter but most people think TIG is somehow superior. The main advantage of TIG, as I'm sure you are aware, is actually puddle control and ability to much more finely control the action at the interface. In the end, the advantage lies with the very source of the problem which is fatigue and the best method to abate that. TIG welding makes it much easier to get a nice large toe radius which is mandatory in increasing the endurance limit. Controling starts and stops? I can do that with a MIG torch just fine. I have mine set up for some post purge if that's what your worried about. The factory welds are usually adequately penetrated. Whenever making a repair, you should remove all the bad weld. A gusset would always be a good idea to distribute and abut the stresses generated under operation. Ever heard of scab plates?
The entire area surpasses any annealing affects you do to it but that should be important if you are not going to use gaskets. You should anneal it so it will sit flat on the head. Tempering it will lessen (but not eliminate) the welding stresses in the HAZ. Scab plates aren't evil.
Anybody can weld pipe, putting together equipment is REAL welding !
(Just a friendly jab) I've worked with nuclear welders and inspectors from Clinton, IL and Cordova, IA at my previous jobs when they got laid off and came to work for us.
BTW, I've talked to several OSU weld engineers who think they know it all about welding. Give me a break. I understand the electrical and mechanical theories and have been involved heavily in welding steel (65mm to .8mm plate) for a few years.
I will admit that my expetise in the material end of it isn't what it should be. 99% of all my welding has been with Lincoln L-50 wire.
