DS header had a pretty large crack on #5 tube. A friend fixed it with his TIG using nickel filler (he stated that nickel is ductile and would relieve stress from the weld better than some other wire choices). he also welded a brace between 3 & 5 tubes as suggested by multiple other posts.
Checking flatness of the header flange on a machinist stone, there is a 0.025" gap on the surface to #5. This gap can be shifted to #1 by rocking the flange over the high spot in middle. the surface is not twisted, but bent back at #5 (or #1).
I've seen a lot of comments stating that the flange surface should be milled flat (<0.005"), but it seems like bolting these to the heads (which are on the car so I have no idea how true cylinder head surfaces are) would pull together the 0.025" gap i'm seeing on header #5. Maybe some high temp RTV for insurance?
