Jul 14, 2004 #1 G gnxis New Member Joined Mar 7, 2002 Messages 168 will the o2 sensor get different readings if its in the dp rather than in the header. which would be better?
Jul 16, 2004 #3 R rkreigh Member Joined Jun 7, 2001 Messages 127 I wouldn't do that. the turbo absorbs quite a bit of heat and it would probably throw off the 02 readings. not a good idea.
Jul 16, 2004 #4 D DavzGN Well-Known Member Joined May 28, 2001 Messages 1,397 Which type of O2 sensor, narrow or wide band???? NB you want before the turbo. WB you want after the turbo. HTH David
