jarredsoon
- Aug 9, 2007
Hey man you should just put new headgaskets in yourself and save some money and see how the car runs. It's not really that hard if you have a place to work on the car.
tta983 said:The cylinder walls are scored pretty badly also. Will have to be rebuilt or get another short block....
tta983 said:I have it at a shop here in Jax, the owner evaluated it himself. I know the heads are still on the car. I just took it over there today and I got the news just a few minutes ago....
Just reading these two posts has me scatching my head. I would honestly get that car back to the house as soon as you can, because if they are telling you that you scored the walls badly without even taking the heads off, then they are trying to screw you. What will happen is they will throw new gaskets on for you then, then clean the tops of the pistons, while telling you that they honed the block, and installed new pistons, when they didn't. Take the advice above, install new head gaskets and call it a day....
If you have a socket set and a torque wrench than you can do this. I had never thought I'd be able to do it but I did anyway with help from others who had experience over the phone. It's not that bad. Just be sure to buy new fasteners and clean the Parts really well. All the guys on this forum will answer any question you may have. You'll be really happy with yourself when all finished too
And would you take your TTA to a shop and they were curious what PAS was.
Yes....that doensn't classify a shop as good or bad IMO. You can know the GN's inside and out and not know what ASC was or PAS for that matter.
I ran 10.5 at 132 on those piece of junk pistons
Typically if you pop the HG it wont have compression. #4 is not the typical cylinder that goes. Typically its #3 on the drivers side.
You must of detonated the daylights out of the motor to create enough damage to require a rebuild. I popped many a head gasket on a TTA.. never needed anything but a gasket. My worse one happened with Cometic gaskets and it tore up a piston. I installed a new piston and back on the road it went.
Blocks are tough on the cars. As are the pistons.
This is why I say pull heads and post pixs. If your at the mercy of a shop.. you may want to get a second opinion.
FWIW.. TTA pistons are different than GN pistons. Doing a rebuild can be pandoras box.
