Headlight Harness Question
DaveyX87
I want to upgrade my headlights soon. I noticed Kirban has the H4 harness. I also see that Casper's has a headlight brightener harness? Are these the same thing? If not, should I get both? I'm confused when it comes to wiring. Thanks.
Kirbans includes the hotwire harness along with the H4 housings & bulbs,
Casper's is a hotwire kit for the stock sealed beam headlights
The H4 hi/low beam bulb has a different pin out then the stock sealed beam bulb/lamp. This is a main difference in headlamp/relay kits.
Mix them up and the hi/low headlights (outer) won't work correctly.
RemoveBeforeFlight
