I knew the day would come when the headlight motors would fail on the TTA and that day is today. The headlight initially flipped up then dropped down. Headlight will no longer flip up. Motor still activates but the internal gears don't seem to "grab". Attempts to raise the light with manual turning of the knob on top of the motor assembly fails to work. If anyone has already gone thru this repair your suggestions will be appreciated. Does the whole motor assembly need to be replaced or can the internal gears be repaired separately? I have yet to disassembly anything but I know the motor itself still works but basically nothing happens. Thanks for the suggestions and wisdom.
Dean
Dean
