Heat Shield Question
my85grandnation
85 Triple Threat
On my 85 Hot Air GN the heat shield that is tack welded onto the drivers side header is about ready to fall off. I am going to pull it off completly this afternoon before I loose it while driving around. My question is, do I need this shield to be there? Is it protecting anything or do I not need it at all. If I need it then I will get it welded back on but if not Ill just leave it off. Please let me know. Thanks
Dusty
I don't think I have even seen a set with the shield still on! I assume it is there to protect the upper A arm bushings, etc from heat. If you have time to get it out and welded, it may not be a bad idea. If you don't have time, or don't want to, remove it and save it for later. :redface:
