Heat stopped working.......
The heat stopped working in my car. when you cut it on, it does not even blow. Any ideas of what this could be?
If it isn't blowing I would have to think it could be the fan motor. It is under the hood on the pass side fire wall. Pretty easy to swap in a new one.
My guess would be if you have no fan at all--check the blower resistor module on top of the hvac case. If the resistor(s) are blown no fan or only one speed may occur depending which resistor wire broke. It is used to give you different speeds on your fan. Local auto parts or Amazon will have replacement. Thanks. Dp
