Heat
TURBO D
Will the trans build up the same heat foot braking vs. using a trans brake in the same amount of time?
Darn close.
The main difference being that a trans-brake will allow you to stall the converter a bit higher because you are not overpowering your rear brakes.
Other than that, you are converting 100% of your engine power to heat either way. :eek:
