Start by verifying that you have vacuum. The vac source is shared with the EGR and cruise control. There is a check valve on the firewall in the engine compartment behind the driver side valve cover. From there, it runs along the firewall to the passenger side then into the passenger compartment. There is a connector behind the glove box door, and I *think* the vac source is the purple line. You just have to track the vac lines, etc.
