May 9, 2015 #1 D dgreen Member Joined Dec 4, 2011 Messages 64 87 gn when under accel heat comes on full blast (not blower just temp) at idle seems to get cooler a/c compressor works (134a system) pressures good, any ideas? I did replace the one way valve under hood. are there any others? Thanks.
May 9, 2015 #2 Chuck Leeper Toxic old bastard Staff member Joined May 28, 2001 Messages 16,530 Door in the heater box may have the plastic lever broken off, and the door is swinging loose. Glove box out, and U can see it.
May 11, 2015 #3 D dgreen Member Joined Dec 4, 2011 Messages 64 Chuck Leeper said: Door in the heater box may have the plastic lever broken off, and the door is swinging loose. Glove box out, and U can see it. Click to expand... Thanks Chuck Ill check that next.
