Heater Core
11secondgs
My girlfriend got a splash of water on her big toe, while I was running a 1/4 mile out in the country. I was at about 22 psi. I checked the heater hoses on the engine side and they are dry. Where is this water coming from. Also, behind the front rear tire, there were also drips. I couldnt visually see anything leaking anywhere? There was nothing more than a few drips inside under full boost?
Have you guys seen this? Where would it be leaking from? How do I fix this? Any ideas?
Were you....
operating your a/c? It may just have the condensate from the high humidity outside the vehicle. If you are using anti-freeze, and the the drop on her foot or outside on the grd, is green or slick, you may have a pin hole in your heater core.
OK - I took the car out for about 2 hours of driving and many short full trottle burts.
I could not replicate the water.... I also did not have the AC on when the water came in on her big toe as we had the windows open????
Any ways, it appears I missed a bullet, but it had me very concerned.
So, I will forget about it until It happens again.
Thanks for the input.
JP
