Who makes a heavy duty actuator with a base setting of lower than 18psi boost. I dont want a stock act. but I thought I read somewhere a while back you can get ann actuator with a lower tension spring. I need to get my boost down until I can afford to buy the alky kit. 18psi is just a little too much for pump 93 octane.
The highest boost ill turn it up to will be 24-25psi.
