Hello Fellow Buick owners. I just wanted to post a detailed shifter cable install since the final one I installed from High Way Stars broke after a year of use for me..That one fit perfect by the way.. I had it in a bag in the house in a top drawer still in the bag & installed it year ago.. It broke at the beginning of April 2020. So now time for hopefully a FINAL alternative to the broken cable issue that so many of us have.... I do not know the durability but looks excellent quality & tuff. Hopefully an answer to all of our woes. I did read on Some threads earlier on this cable that they couldn't get it in Low1 which I need since I have a T brake. One person did say he got it to work perfect with room to spare, but I wanted to know HOW? So at a $100 a pop I was always hesitant to buy it,, but now I did..It's adjustable on both ends... So here goes....some pics are blurry Sorry.
Highway Stars
Mikes Montes
This bracket actually came with it I was going to modify mine but didn't have to since this one came
I did have to contour the bottom bolt hole (didn't take pic) in order to fit my Pan to keep from hitting the tapered pan rail lip... I have a grinder so no biggie,, may not have to with the stock pan.
Sorry I didn't measure,,, just know that it works
1) Remember settings on your chip-stereo etc. Unhook the Neg. battery cable in case wires touch from your gauge pods if you have any below the stereo.
2) Chock the back tire, Raise the front end or drive on ramps,, I have race ramps for both tires.
3) disconnect the shift cable under the car at the Shift linkage on the trans.
4) Get in the car switch the ignition on forward so you can move your shifter handle freely.-----Take the t-handle clip out the side, pull up gently lay to side ,take out the ash tray--gauge pod console if you have one ,,,,console bolts, screws etc. keep up with them .. Raise the console high over the shifter handle & lay the hole console to the passenger side somewhere.
5) Get the new cable with the screw & attachments all off the shifter ratchet end & route up through the bottom of the car here:
6) Put the other end here out of the way
7)
Put back the first nut on this end,,,going to take some wiggling gently to get it in that hole
8) line it up to try & attach to the lever,,,
BE BACK SHORTLY I CAN ONLY ATTACH 10 FILES...
Highway Stars
Mikes Montes
I did have to contour the bottom bolt hole (didn't take pic) in order to fit my Pan to keep from hitting the tapered pan rail lip... I have a grinder so no biggie,, may not have to with the stock pan.Sorry I didn't measure,,, just know that it works
7)
