- Aug 24, 2012
I got the sway bar mounted to the axle, but am having an issue with the end links. I installed the links in the middle hole and drilled my 1/2" holes in the cross member right where they should be per the instructions. The brackets for the end links with the 1/2" bolts will hit the exhaust if I mount them facing straight ahead. The ONLY way to avoid this is to either 'modify' the exhaust with a hammer, or tilt the brackets out(facing the tires). I'm not that concerned about the exhaust since it will be swapped out for a Pypes exhaust. But, I am worried about tilting the brackets out to clear the exhaust since I don't know how this will affect the bar's performance. I know I can't be the first to encounter this issue since so many hear have already installed the Hellwig sway bar. Any suggestions???
