As stated above, car gets weak at 5600 and is flat at 5800. Air/ fuel ratio will go to 10.1 to 1 if you stay in it. A fast mechanical "type" sound can be heard above 5600 but no popping or back fire so i'm thinking the valves are floating right, well i had (2) springs checked today, results are 150# closed...350# open,which is what RED, Dave Weber, and Tom at Champion all said should be good enough to stop floating. So now i'm looking for more idea's....TIA......Greg Crabtree
A few specs.........................
1) ported 14 bolt GN-1s
2) 1.65 T&Ds split shaft rockers (very nice BTW)
3) 214-214 Comp/ Weber Racing hyd. roller kit
4) .584 lift W/1.65 rockers
5) installed height is 1.830in.....1.842ex
6) heads ordered thru RED with these recommended mods....1.440 O.D. double springs,titianium ret. , Inconnal exhaust valves.
7) Fast B-B, 83s, BB-70Q, PFMIC,
