doing a vac conversion today. everything going smooth until time to remove brake lines from the powermaster master cylinder. the one at the front of the car came out smooth as a baby's ass. I can't get the one closest to the firewall to budge. Yes I'm using a flare wrench. SOB has rolled over. I'm about ready to grab it with a pipe wrench. Any suggestions on getting this mutha off? I've got penetrant on it right now to see if it'll loosen while i take a break & do dinner. I DO NOT want to have to change a line.
I've been through this before with the brake line to the rear drum set up. Ended up replacing a line. I would imagine that the rear line is both easier to find and easier to swap out. I figured I could borrow a flaring tool from the parts store, but their monkey tubing flaring tool wouldn't flare the thicker brake line back there. The lines on the mc seem to be the same as those.
Any suggestions from anyone?
Thanks for any input you might have.
