Here are some parts that I know I have, if you need something thats not listed here, ASK! I may have it. All parts are for 86/87 turbo regals.
2 sets of 8445 heads complete with stock springs and valves (Needs cleaning) $40/set
1 set of new Clevite stock replacement pushrods $15 SOLD!
1 stock air cleaner assembly w/FREE K&N air filter $15
1 street chip (93 octane, 20 deg.) for 55 lb injectors, not sure of maker. $15 SOLD!
1 set of air conditioning lines $40
1 stock electric radiator fan $50
1 stock gauge cluster $100
1 gauge cluster dash plaque $50
1 set (driver and passenger side) burgandy rear window trim $50
2 under dash (above gas and brake pedals) stock plastic covers $15 ea.
1 blue dashboard gauge cluster glare shield (peice of dash that pops out behind steering wheel) $20
2 sets of chrome wheel well mouldings $15/set
1 set of front and rear chrome window trim $20/set
1 set of stock rear coil springs $20
1 set of turbo t wheels (been in accident, requires professional wheel repair) $FREE!!
1 set of stock concert sound speakers $15/pair
2 MTX 10" Thunder 4000 subs in separate sealed boxes with neon light rings, works and sounds great! $50 ea.
1 JL 10" sub in bandpass box (27" long by 12" square) Had for a while now but, still sounds great! $25
1 Kenwood cassette deck with MASK automatic rotating face. Have to check model number. Works fine $50
1 stock AM/FM cassette deck w/auto reverse (no EQ) $25
1 Astron 14 volt D.C. 50 A power supply Works great. $100
Can't remember the rest, I'll update this later. For now, if you see something you want, than call me (808) 429-5593. I dont check the board as often as I used to so CALL!!!
Thanks,
Derek
Thanks,
Derek
