87 GN, 58K miles, bone stock.
I've been having a problem with my car for the last 2 weeks.
Once every so often it stops running mid stride. I don't mean under boost. Just normal daily driving. I've had it towed 3 times in the last week!
When the car stops running, it will fire back up but only stay running for 3 seconds then dies. Funny thing is : next day it runs FINE! And may continue to do so for several days!
Replaced fuel filter / fuel pump / installed FP gauge since I thought it would be a fuel problem. Swapped out Coil Pack and STILL didnt make a difference.
Then, when I realized this only happened once when it was raining and twice shortly after car washes. I had it washed , replicated the problem and looked under hood for water. Only found water behind each headlight cluster. Checked ECM plug off battery; it was fine. Checked under vacuum canister: the filter was SOAKED! Not to mention full of mildew and muck! Removed it.... car runs fine.
Think I really solved this problem? Or maybe it dried out when I was monkeyin around with it? Feedback pls! I'm scared to drive too far for fear of being towed home again! (maybe I should buy a tow truck next?!?!)
Thanks!
Thanks!
