TurboMonte 2
Car Nut
 - Mar 21, 2006
Eyup--bad MAF will buck/ miss even @ cruise (you can ck for code 33 or 34 via ALDL port w/o scantool).  If missing, etc primarily under load then it's likely ignition (coil pack/ICM) and/or fuel supply (typically low pressure/flow).
Good luck & you'll find the Scanmaster invaluable in both trouble-shooting and proper tuning...
You're definitely thinking properly in long term with LT1/LS1 MAF sensor + Translator...
