Apr 4, 2016 #1 T turbotrix2004 Active Member Joined Nov 2, 2013 Messages 342 I was cleaning up my vac lines and broke a t of some sort anybody know what this is and where I can get another?
Apr 4, 2016 #2 G guerrajaime845 james 87 Joined Mar 28, 2016 Messages 11 Its check valve broke mine to i bought mine autozone.Help section part# 47150 Sent from my SAMSUNG-SM-N920A using Tapatalk
Apr 4, 2016 #3 1KWIKSIX Well-Known Member Joined Sep 29, 2007 Messages 3,254 Highway Stars has em www.highwaystars.net http://www.highwaystars.net/vacuum-check-valve-two-way/ Kirbans Performance too! http://www.kirbanperformance.com/product/455/TWO-WAY+VACUUM+CHECK+VALVE+#7207.html
Apr 10, 2016 #4 L lhbarrett Member Joined Jul 25, 2003 Messages 201 Go to your pull n pay go to the GM section and gather up the assorted vacuum lines in the best condition you can find. Then order anything that is missing. Do not forget the vac block, gasket, and pvc as those get old too.
Apr 10, 2016 #5 N Nick Micale Tech Advisor Staff member Joined May 26, 2001 Messages 9,208 That is a check valve as well as a tee, so be sure you get the proper replacement,
Apr 10, 2016 #6 T turbotrix2004 Active Member Joined Nov 2, 2013 Messages 342 Ordered one from kirban, thanks for all your help
Apr 10, 2016 #7 M MCH86GN Well-Known Member Joined Aug 20, 2008 Messages 1,478 For reference, for anyone else, I picked mine up at O'Reilly's.
