Stockbroker1977
- Jun 1, 2009
Any idea what the common cause of this problem is? Also, how does one go about fixing this? Where is the sensor location...is this sensor simply replaced?
Number 22 engine code is: Throttle position sensor (TPS) - signal voltage is low during engine idel OR fuel cutoff relay circuit open or shorted to ground.
Engine mods just done are: new plugs, 160 degree thermo., 3" Kirbin downpipe, high flow cat, K&N filter and mass pipe, hooker cat back exhaust.
THANKS FOR ANY HELP YOU CAN OFFER!
Jason
Jason
