Help ID'ing car
#1
Can someone please help me ID the attached car? I'm leaning towards 1986. The split side window has me confused, I can't find others like that, and I can't make out what it says behind that window. The combination of the hood, luggage rack, spare tire and leather seats have me thinking it's a turbo with custom items added. Thanks for your help.
TurboTGuy
Gray Beard Member
#3
https://en.wikibooks.org/wiki/Vehicle_Identification_Numbers_(VIN_codes)/Model_year
If you want to look at it another way, the model year code is represented by the 8th digit in from the last digit of a 17 digit VIN.
Example : VIN # VWAW15WS12VFE5432
That V in the same spot would indicate a 1987, a 7 would indicate a 1997 and an H in the same spot would indicate a 2007. Current model 2018 year models are represented by a J.
Hope this helps.
TurboTGuy
Gray Beard Member
#4
Hope this helps.
Well, I'm glad I proof read my response. Holy CRAP I messed that up!
That H in the same spot would indicate a 1987, a V would indicate a 1997 and a 7 in the same spot would indicate a 2007. Current model 2018 year models are represented by a J.
Sorry for the confusion!!!!!!!!!
INEEDAGN
Seen Your Member
#5
I'm guessing it started life as an 86 wh1 and had the vinyl top, luggage rack and continental kit added to it from there. Looks like it might have a third brake light and I wish i could read the emblems on that vinyl top.
#6
My guess:
87 turbo limited that was customized by the dealer or the owner shortly thereeafter. That vinyl top and continental kit are both 80s conversions. Lots of upholstery shops did stuff like this back in the day. Absolutely awful.
INEEDAGN
Seen Your Member
#12
The script on the vinyl top probably reads the name of the coach maker and that'll give you something to google. But yeah it's an 80's custom/coach built and not factory. Still cool though.
TexasT
Texas, Where are you from
#14
I'm thinking we need more pix of this rare machine. Thirty yrs after the grille isn't much of an identifier. We need some pix including the spid label and more of the interior, door panels to be specific.
I love the eighties!
White walls FTW!
NY Twin Turbo
All the good stuff.....Times 2.
#15
:confused:OoohF!
