Ok,
Don't really know where to start............... New coil new module(86-87), resisted wire eliminated and hotwire to alt. is done. Took car to the Dyno, ign breaking up know matter where I gap the plugs at(22-30). Also tried running a one step colder plug(NGK ur5) and still did the same thing with it gapped to 30. Car seemed like it was going to make pretty good power 170whp and 240trq(at 15-16 psi) at 3000 then broke up real bad. Not sure if it is an ign problem or not but I went ahead and ordered a set of ur6 plugs and was going to try and gap them to 33 and see what happens. Was trying to have the car ready for a local event this weekend but doesn't look like I am going to make it at this rate. AFR's seemed pretty lean to me, but it didn't like anything below 12.2
On strait 93.
Any help would be appreciated even though I know you die hard hot air guys don't like what I did with the car:wink:
Thanks,
Dee
Thanks,
Dee
