Goin crazy
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
It just may be that the battery is the problem. W/ only 10 VDC in it, Have you tried to charge it overnite and then check it? You may also take it to a PEPBOYS or some other chain parts store and they will pull a load test and tell you whats wrong, if anything. Be sure to "fully charge it" first, otherwise you'll have some waiting time for the test to be done. Sounds to me like a cell, [2.2volts] is a dead player.
Other items:
Cables. You DID hook up the ground to the engine block didn't you??
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
They ARE the good cables, right??
The charging wire to the battery is not toasted and running w/ the ends fried?? Same goes for the power and grnd cables. If they are green and corroded up inside the covering, they ARE toast!!
The starter is fresh and working right??
Other problems such as erratic, rough idle and cold start stalling:
Bad MAF.
Air leaks in vac lines.
TPS set wrong.
Temp sensors fried.
Bad connections.[Saw some comment on changing ECM's and Mafs] CHECK ALL THE WIRING!!
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
How bout the grnd wires on the cyl head??
Burned or loose fuseable links.
Cam sensor is correctly set?
The crank sensor is not junked by rubbing the interrupter ring??
Fuel pressure is right?
Ecm hasn't been rained on thru a dash/ w. shield leak??
Coil pak/ module checked w/ a Caspers tester?? DO NOT rely on a VOM to do this!!
Bout all I can think of . Gettin REAL old and have "CRS" setting in.
HTH,
Back under my rock
![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
