Turboholic87
You feeling lucky punk!
- Apr 22, 2007
Was checking the main bearing clearances today and found them to be 2.5-3 thou. I'm using a new cat crank & Std. FM 107M 3/4 groove bearings. My machinist quoted me .0018 when I asked him but who knows how well he checked the clearance.
The block was line honed with a girdle and I'm wondering if the bores are too loose which would mean the bearing crush is insuficient. I used a dial bore gage & plastigage with the same results. Crank mains measure out at 2.4994-2.4993 which is very close to the Hayes manual spec of 2.4995.
Am I missing something or just making a big deal and should run with these clearences? What should the main bore diameter be and how can I check proper crush? Any info would be helpful.
Thanks,
Greg
Thanks,
Greg
