blacknight80
- Dec 26, 2013
SignUp Now!This is a HA draw through car so it's got a distributor that you get the tach signal off of.The green plastic plug is the tach wire if you run an aftermarket tach hook it up there.... (highly recommended since the factory bar graph is usually way off mine was off by 800 rpm)
