Hey guys.
I would really appreciate it if i got some feedback. I changed the pressure switch and accumulator. The fuses are ok but the pump does not turn on at all and the brake light is always on my gn. I tried last night to bleed the system from the booster side (2 nuts). Fluid with key off dripped out very little. Th pedal went down a little. How do i check if the pump motor is the problem. I have a multimeter that i bought at walmart but am not really sure on how to use it. How do i check the grounds?
This brake system is driving me crazy. Will bleeding the system cause the motor to run?
Input please guys..
Thank you kindly...
Michael
Input please guys..
Thank you kindly...
Michael
