Help needed: T&D instruction sheet for Champion alum heads
turbodave231
Moderator
I need a copy of the T&D instruction sheet for the individual shaft mounted rocker system for Champion heads.
This is the system that is similar to Jesel rockers not the single shaft (i.e. stock rockers)
Thanks in advance
Dave
I never saw an instruction sheet for these but have ran them for years. They seem to
Need approx .090" of shim under the bolt down pedestal with standard length valves. The pushrod holes in the heads will need to be opened up with a mill. Rocker geometry and pushrod clearance needs to be checked.
the instructs for the TA SE jesel setup should be the same , i dont have them scanned in but could dig them out
i didnt find the install instructs but did find my assembly notes
the base gets installed to head at 35 lb/ft
I have the instructions in the garage. For some reason 45 ftlbs sticks in my head. I ended up with no shims. These are the latest castings. I had the first castings and they were a totally different height. I did have to cut the bolts that hold the pedestals down.
