84 ttype, ignition module tested fine, ecm has power and new crank sensor. And still no spark and fuel pump not kicking on.. and suggestions? Wire that I need to check?
Check engine light does come on and all fuses are good. Checked all of them for power they all seem to be ok. Ignition module does have power going to it, but all other sensors dont, cam sensor does not crank or fuel.. tryed another computer and still nothing. Ive never seen anything like this before
if the fuel pump is hot wired or after market it might have another fuse somewhere else, like mine is in theengine compartment near the map sensor on the passenger side, thats all i can think of right now
