86GN-862+2
- Apr 19, 2008
It's got 170K miles and was running great. Now it is popping a code 0301 which is a misfire on cylinder 1 according to OBD code booklet. I've replaced plugs and checked for spark and it's all good. Thinking injector may be done for it stumbles at idle but runs strong under load. Another peculiar thing happenings is that all the lights are dimming as it "misses" when idling or under acceleration. Weird as this may sound, it seems to have started after I had it detailed and the detail shop just sprayed the crap out of the engine bay to make it shine more. I don't know what they use but could be that armor-all crap. I have also ran two cans of injector cleaner. B Chem-tool(l think) and after fuel up again I poured some seafoam. I cleared the code several times but it keeps coming back. The wife did run the thing low on gas a few times too. It was so low on fuel that while running some errands, it almost killed the engine as I was making a turn. Maybe it picked up the trash in the tank and plugged up a few injectors… I don't know. I also replaced the fuel filter BTW. Sorry for a long post but just trying to put down everything as it happened. Any help is appreciated.
