Help Please!!!!!!!!!!!!
stangkiller
OK..My 87 TR has been getting this rpm surge so i unplugged the TCC Solenoid,and no change,So i put on a new maf new coil pack...no change.I checked the ignition mudule and it looks new no melting or cracking.One day i got in to drive it and i got a code 41.I changed the ecm for one i had in my garage..same thing.I unhooked my battery afterwards.I put it back and now i want to pull the plug on the cam sensor while its running to check that.Now after pulling the battery for some reason it wont code.Now it ran great yesterday.Does a cam sensor just go bad or what.How about the ecm.Now its running great..well for 30 minutes at least.I dont want to drive it till it codes cause i dont want to get stuck somewhere.Any ideas?
After you make changes have you been unplugging orange wire by the battery to reset ecm?
Checked all your vac lines? Do you have a scanmaster or any such device?
