8
86ls
Guest
On the way to work today everything was fine (about a 30 min trip) once I arrived at work I stopped at a stop sign when I went to take off NOTHING 3000rpm and about 2mph, so I dropped it into third and the car went as advetised and shifted fine. While driving in 3rd I put the shifter back in OD and the trans started to slip, I pulled over to ck the fluid and TV cable all OK I went to back up and again 3000rpm about 3mph in reverse.
I don't know if this matters but on Sat I put in a 2800 stall converter. The car was fine until today.
Thanks for your help in advance. If I need to ck something let me know where it is and how to get at it as I am not a transmission expert.
