A
		atl gn
Guest
Ever since I cleaned my engine, my car has been running hot.  It went from running at about 160-180 to getting well over 200 at idle.  Of the three relays on the drivers fender, I have changed both of the small ones and still the same.  I know that the big one is the problem one, but I want to make sure that it is nothing else before I spend 50 bucks on a new one.  Can the fan motor or other sensors go bad when they get wet?  I cannot tell if the fan is running on high or low, but it is definately running.
Also, if my temp gauge(that is pretty new and should be accurate)shows over 200 degrees and the clt function on the scanmaster reads 185, which one should I go by. Where does the scanmaster get its reading from anyway?
