D
Dave85
Guest
Friday I bent a pushrod and it has been nothing but trouble since. I replaced the push rod which was on the #1cylinder exhaust side. The spark plug was fuel soaked badly so it was replaced. It is still running rough. I'am still getting a fuel soaked plug on the #1. Cam Position is set, I have spark on #1 but it jumps around on the electrod not a nice constant spark like #3.
While running I unplug the MAF and it still runs the same. I'am getting no check engine light till MAF is unplugged. Usually when the MAF is unplugged while running under smooth operating conditions it stalls out. I tried tapping on it but that didn't do much. What I don't understand is the fuel soaked plug on #1 all the other plugs look good. I have a brand new module I'am going to try but for some reason I'am thinking MAF. What do you guys think. Thanks
DAVE85
DAVE85
