If you car is running then it's just hooked up wrong. Power to an ignition wire(can use the ignition terminal on the fuse box),
Needs good ground, White wire to ADL
If you check engine light comes on when you turn your key to the accessory position and you have no reading on your Scan master then it's hooked up incorrectly
