Help- Speedometer reading is way off.
fastjack1
The reding is way off between my stock speedometer on my 87 GN & my OTC2000 meter . 5 mph on speedometer reads 15 on the OTC. 30 on the speedometer reads 50 on the OTC. 60 on the speedometer reads 95 on the OTC. Tire size is P215- 65R. The readings are only 2MPH difference on my 86GN so I know that the OTC meter is working correctly. Who knows what the problem is. The stock computor has been modified for low impedance injectors, if that makes any difference. Thanks.
is it the stock 85 mph or is it a 145mph replacement? If it is the 145mph replacement, it could be a reducer causing the problem.
David
87GN
David
87GN
If he had the 145mph speedometer and it was calibrated correctly with a gear reducer I would think the OTC would read lower.
