Help wiring an SMC Alky kit
huntsg
TurboBuick.Com Supporter!
I'm trying to set up an old smc alky kit for a friend. The kit was handed to me in a box. It has the controller, wiring and a bottle with pump inside. The bottle has a pressure gauge mounted to it, two wires coming out for the pump, and an RCA jack on the top that i think is used for low alky level There are four wires (white, green, red, and black) that go from the controller to the bottle/pump and some have been cut. Does anyone have the correct wiring for this? Thanks.
Red and black go to the pump red on the center pin of the RCA jack.
White and green go to the float level switch for low alky.
Thanks. Is the float level switch below the pressure gauge? Also, other wire from RCA jack is not used?
If you look inside the bottle there should be a red and black from the pump.
I've never had a pressure switch on my kits so I wire the controller red and black directly to the pumps red and black inside the bottle.
2 wires to the pump, and 2 to the float switch which is also easy to see the wires and tube inside the bottle going to it.
