Ok, I am already doing a search so please don't immediately start with "Do a search..." but while I look I thought I would post here and see what your guys thoughts are on my issue.
My car has been having some issues with knock. When it is cold I can get up to 19 degrees of knock on the scanmaster. When this happens it is not under boost (usually at 0 on the guage).
I ordered a new chip from Turbotweak for my setup and thought that would help.
My old fuel pump died (Reds XP) so I got a new one from FullThrottle and a new billet fp reg.
I have tweaked on it and still have the same knock problem although it does run smoother with the new chip. I can't say that I have ever heard any knock (exhaust is kinda loud).
When the car is warmed up (160) it doesn't seem to knock much at all. The really high numbers only seem to be when I first drive it in the morning especially when it is cold.
I may have that figured out and will try to warm it up real well before I go out in it to see if anything changes.
Now the other problem is after all these changes my blms seem to always be above 139 (around 140-155). I have tried adjusting fuel pressure but it hasn't seemed to change anything. Before I had the blm's right at 128.
If I am at idle BL will be right at 140. if I lightly touch the throttle it will move right to 128 rather quickly. If I am cruising it will stay right in range.
Here are the scanmaster readings after a ride into town tonight.
o2mv mostly around 800
bat=12.8
AF=12
LB=38
BAT=12.8
INT=128
BLM=147
CLNT=162
ATS=98
RPM=775
TPS=.42
IAC=13
CC= (Seem a little "lazy" now, but given a little throttle seem to move around fine as normal)
FP is set at 48 line on and 52 line off.
no malfunction codes
Car has a stock turbo, 37lb injectors, newest walboro pump, hot wire kit, Earl's braided lines from tank to rail, adjustable billet regulator, SMC alky kit, 3" single shot exhaust, NKG plugs, stock heads (replaced valve springs), liquid intercooler.
I have already checked for vac. leaks and fixed one plug that came off, other than that there doen't seem to be any leaks.
Car does seem to run fine just concerned about the BLMs.
Any suggestions?
bat=12.8
AF=12
LB=38
BAT=12.8
INT=128
BLM=147
CLNT=162
ATS=98
RPM=775
TPS=.42
IAC=13
Any suggestions?
