boosted231
- Sep 13, 2003
I just failed MO emissions again.
HC standard .8000
My HC was 2.4565 Fail
CO standard 15.0000
My CO 9.7205 Pass
NOX standard 2.0000
My NOX 4.6375 Fail
My car, stock injectors and turbo, adj FPR, TDP with cat- about 2000 miles on cat, walboro fuel pump hotwired.
Just changed the O2 sensor, maf, crank sensor and put a tt emissions chip in it. The lowest I could adjust my fuel pressure was 40 line off.
I also put a bottle of seafoam and heet in the tank.
I took the egr off and there was no carbon build up. When engine is running and I push diaphram up engine stumbles. I did notice that the egr solonid filter was nasty. I had to order from GM. Have factory pcv valve that I cleaned and put back in. Cant find any vacume leaks.
Car is basically stock.
Could my injectors cause this problem, I would like to get some new ones.
Can anyone steer me in the right direction, Thanks
HC standard .8000
CO standard 15.0000
My CO 9.7205 Pass
NOX standard 2.0000
My NOX 4.6375 Fail
