i need a lil help with the me-r settings...i cant seem to get it to stop stuttering and or staul out in drive and reverse...does anybody have a website or know the settings for the me-r?
i honestly dont know wut version i have...its the thumb wheel one...my bro had bought it an it was working fine till the car sat for a month and the battery went dead...it stutters when i try to take off in gear...it just hesitates and sometimes stauls out...i really dunno wut to do
Had a very similiar problem with mine after sitting up for a period of time. As it turns out after checking everything known to man.....It had corrosion on the chip and ECM prongs/terminals what ever they are called. Just check you connections for corrosion, worth a shot:wink:
My battery recently died and I had to reset all settings in chip.If you are using wideband correction make sure its on the right afr.I would check everything out before driving it too hard.
One other thing with the MER, if it is a few seasons old with the wideband correction, set your xfactor fueling to enable at 150mph. If not, the afr will default to 9:1 or so and really fall on it's face once it hits exactly 100mph. Eric did offer to fix it no problemo though.
After I built the stroker, the car wanted a lot more fuel in park and drive positions, or else it would stall as well.
