Help.. With my 85
mr.La Rue
I have an 85 grand national i'm a having a problem with my ignition control module and can not find one to replace it, can i use a 86 or 87 module??
PM sent...
I would suggest converting to the 86-87 setup... you will need an adapter for the wiring as only 4 wires are the same place... I would post these questions in Hot air section- my .02
parts required to convert--prices may have changed- from a old thread in Hot air basic info thread
$ 32.00 - ACD# D552 GM# 12353801 -- Coil Packs
$149.00 - ACD# D1996 GM# 24503624 -- Ignition Control Module
$ 34.95 - 102085 -- 1987 Coil to 1985 Mounting Plate -- Caspers
$ 69.95 - 102087 -- 86-89 CCCI Hotwire Kit -- Caspers
$ 49.95 - 108016 -- CCCI Splice with Crank and Cam Plugs - Special -- Caspers
$ 13.05 - Shipping
$348.90 - Total
Thanks a lot.. I already have a box and an ignition module/pack and its already mounted i just need to know where i can find the wiring diagram for them both i have look and look but i can only find one for the 87 cant find any wiring diagrams for the 85.. Thanks again for your help
PM sent... there is info on gnttype.org in technical service section-
but I can't get on that site... :mad:
