gearhedjon
- Dec 14, 2005
Hi just rebuilt my NA V6. It Has a stock rebuild with stock compression. Poston's cam, Kenny Bell intake 78 exhaust manifolds- no dog leg on the passenger side, true dual exhaust,200R4 trans with shift kit and 3:73 gears.I am currently running a feed back carb with this set up. My problem is I can't even spin the tires! When I punch it it bogs and won't go Yes I have the secondaries tuned and the carb is tuned right too. I even drilled the accelerator arm for some more pump shot which helped some. I believe it's just to lean for my set up. Help! I am thinking of sacrificing the gas mileage and returning it to a stock quadrajet and distributor. Any ideas? Thanks
