help with pushrods
1987noblegn
just installed a 218/218 hyd flat tappet comp cam. wondering what size pushrod to go with stock or a little longer? help greatly appreciated. never been this far into a motor:confused:
if running stock rockers and iron heads you should be able to run the stocker pushrods (stock length) but i would consider a better pushrod than the stockers considering the rev potential and increased lift of the cam will increase the pressure and stress on the pushrods
and once its broke in id change out the old springs for new 980s as comp recommends with that cam
63-246-4 - High Energy? Hydraulic Flat Tappet Camshafts
