Hello, some issues on my 87 when cruising during normal operating temperature 170-180, car jerks/miss fires. Runs ok when cold and on the Freeway 60-65. This has been going on for a year or so since I hardly drive the car. I have cleaned TB, MAF, IAC, new plugs RT43’s gapped at .035. Vehicle is mostly stock except for AFPR, TT Chip, 30lb injectors, Scanmaster and Hot wire kit. Nothing has really helped. Cross counts while cruising @ 15-25 mph the numbers went from 3-90 in 21 seconds. Is this normal count jumps? Also my Scanmaster readings warm in park as as follows
RPM 700-800
TPS .42
IAC 15-25
MAL 00
O2 730-760
AF 05
L8 38
BAT 13.6
INT 128
BL 124
MPH 00
CLT 173
ATS 99
RPM 700-800
TPS .42
IAC 15-25
MAL 00
O2 730-760
AF 05
L8 38
BAT 13.6
INT 128
BL 124
MPH 00
CLT 173
ATS 99
