Night_train01
 - Dec 27, 2015
I am looking for advice on solving my smoking engine issue. This problem started the first time I started the car after storing it over the winter. The smoke was billowing out soon after I drove it on the streets.
During the winter I did a little work under the hood, installed new throttle body, valve covers and removed the vacuum block to tidy up the engine. I installed a 1" GN1 plenum spacer, this is where I tapped and ran the vacuum lines. I read a few post regarding faulty PCV valves causing oil issues, I changed mine yesterday with no difference. My car has had the power brake conversion done so of course it requires vacuum, the previous owner teed the brake booster into the PVC line, I did the same thing. I drilled and tapped a 3/8" port into the 1" spacer and this supplies the vacuum for both the PCV and the brakes. I am wondering if this may be the cause of the bad smoking issue., maybe its too much vacuum and is drawing in oil. At idle the car doesn't smoke much if any but as soon as there is a load on the engine the billowing begins. I thought maybe there is oil getting past the turbo and burning in the downpipe, the turbo was working fine when I stored the car.
Any thoughts or suggestions would be greatly appreciated.....
