NEED SOME INFO I JUST INSTALL THE BSTC .....NOW I HAVE A CHECK ENGINE (LIGHT ) FOR BOOST SELONIOD.....ALL THE WIRE ARE CONECTED WHERE THE GO......WHEN I FRIST LOOK AT THE UNIT THE BLUE AND GREEN WIRE WHERE TOGETHER .....AND I TOOK THE WIRE'S APART AND INSTALL THEM LIKE THE INSTALLATION INSTRUCTION SAYS....................DO THE WIRE'S GO TOGETHER ...... ON THE C13 IS TPS OR C7 IS 3RD GEAR..................ANY HELP WITH THIS >>>>>>>THE INSTRUCTION SUCK BAD!!!!!!!! THANK'S FOR ANY HELP ON THIS >>>>>>>>>
