Iwant to the track friday and ran a 13.50 with 40 psi fuel press,15psi boost. Then ran 12.80 with 42psi fuel press and 22psi boost. Where did i go wrong with the fuel press i had no knock.
Should i have left it at 40 psi fp and check for knock or was this ok to up the fuel press. There has to be a way to try and turn these car some with out a scan tool. Should i go up on the fuel press tell it slows up , whats the best way to tune these cars with no scan tool.
Is there any thing else that i should try to tune , the crank sensor is set, cam sensor , i set the tps with the tps tec, should i try any other gap for a high boost like 20-22psi . I hear you can pick up some time by pulling the sway bar off does this work.
My tires are still rubing on the inside this probley does not help ether i just put some oil on the inside of the tire to help it.
Can some one give me a list of things to tune or help get the most out of my car.
thanks ,kevin
thanks ,kevin
