help
corymc
if i only have 42.5s 009s what turbo can i go to? GT6131 or GT6152. i dont have any stall yet was thinking around 3000 and want to touch into the 11s or so.
I also want to get an alky kit once i get the car tuned in but this wont be until the springtime.
Injectors are rated for horsepower.
You can do about 500HP engine, and reach your high 11 goal.
No matter what turbo is on your car.
You need to use a good scan tool to make sure when you are out of injector or running them static since you probably will try to go faster. ;)
I'd pick the best turbo to match the converter you are installing, injectors are easy to change in the future, buying additional turbos and changing out a converter isn't for most people.
Make sure the tranny is up to the task of that 500 engine HP as well.
Seeings I do not know the new turbo lingo yet U could use a TA60 size turbo and easily run 11's.
